Rough ride with air suspension
Douglas Lehman
Raymore, MO
I have a 2014 Ram 1500 Laramie with 4 corner air suspension. I’m getting a stiff bouncy ride and rear seat passengers are being jostled around. Is resetting the air suspension system a good first step to recalibrate the system?
tron67j
Maryland
Has rude always been this way? Have you checked to see if you have a leak? That could be causing the rough ride. There are a lot of threads in the subject of air suspension, you should check them out for similar experiences.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
Is it bouncy on all settings? Is it worse on one setting or another? Generally speaking, the higher the setting the more bouncy the ride can get, with the best being aero and normal settings. There's a reason the truck won't let you go above certain speeds for some settings.
Another question I have...is the truck running on the factory suspension links?
Edward Hands
Youngsville, Louisiana.
5.7 E-Torque
It sounds to me that you are either hitting the limits of travel or you lack proper dampening, or both.
See how far you are from the bumps stops at normal ride height. And maybe try a less rear tire pressure.
