Running Boards
Gregory Allen
Milton, Florida
2019 RAM 1500 Classic Crew Cab 4x4
Can someone tell me what year RAM truck's factory running boards fit my 2019 Ram 1500 Classic Big Horn Crew Cab? I have running boards on my truck with two connections but one of the running boards was badly damaged when I purchased it and I would like to find a used set of OEM running boards that will fit. Thanks for the help.
Dinky
Oregon
You should post pictures of what style you have. There is a few different options and your 2019 classic uses the same parts as 4th gen trucks.
JoeCo
NY
As Dinky mentioned, the classic is a 4th generation truck which has been in production since the model year 2009. Being that the 5th generation began in 2019 and is a new body style, you're best off ordering parts for a 2018 to avoid potentially getting incorrect parts.
Or at the very least if you order for a 2019, be very sure the part is for the classic specifically or DS platform.
Wulf
United States
4th Gen (DS) ran from 2010 (I believe) to 2018, and then from 2019 on as a Classic, so it is likely any year(s) within that range "should" work, as long as like @JoeCo said, make sure it is for the DS platform, and not the 5th Gen/DT.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
4th gen actually started for the 2009 model year.
johnts
Pittsburgh
I beleive there was a frame design change in either '15 or '16. The boards from those years to the current should fit your truck.
Orca
