CHARLES374
Have a 2022 2500 does anyone make a shift kit for it ? It's a 8HP75.
Thanks
Thanks
Unless you plan on tuning the engine and building a bunch more power there probably no need. I'm not even sure any tuners have cracked the 8HP75LT transmission yet. As for the punishment this series of transmission can take let's see is @Wild one will chime in(he knows how to break them...lol).Have a 2022 2500 does anyone make a shift kit for it ? It's a 8HP75.
IF U have a 2022 and having trans issues, FIRST stop is dealer, since U got a Warranty.Sorry for late reply guys. Mine transmission slips sometimes (feels like its in neutral) Turn off truck and restart and it fine for a couple of days. NO light/code's. Dealer says no TSB. How can i tune it ? Thanks
You could put a Zip kit in it,and there are outfits who can beef it up,but as everybody has stated it's an electronic transmission,that can be tuned,but you'd need an unlocked pcm/bypass cable and then find a good transmission tuner who could firm up the shifts with an HP tune,but kiss any warrenty you have good bye.Have a 2022 2500 does anyone make a shift kit for it ? It's a 8HP75.
Thanks
Brought to dealer, no codes/tsb's. Totally stock w 4,000 miles.
It says up covers up to a 70. Mine has 75 Transmission. ThanksYou could put a Zip kit in it,and there are outfits who can beef it up,but as everybody has stated it's an electronic transmission,that can be tuned,but you'd need an unlocked pcm/bypass cable and then find a good transmission tuner who could firm up the shifts with an HP tune,but kiss any warrenty you have good bye.
Zip Kit® - ZF8-ZIP
Sonnax Zip Kit ZF8-ZIP targets the root cause of multiple complaints by sealing the critical circuit pressure losses in the ZF8HP45/55/70 and Chrysler 8www.sonnax.com
I wouldn't stop it and turn it off/on. If you're having an issue, you need the PCM to gather and store that information. If there's a built up history of it doing this, then the PCM will at least throw a 'soft code' that a dealer's code reader can pull. You're under warranty, so by having it do it more often will likely bring it up enough that the dealer will be able to see what's going on.Yes it rev's up high. Does not slam but i stop the vehicle and turn off/on. I use it for casual use only. No it is just random at operating temp always.
Don't quote me on this,but i think i read the 70 and 75's use the same valve body,if so the sonnex kit would fit,but i'd phone or contact them to make sure .It says up covers up to a 70. Mine has 75 Transmission. Thanks
