shock extenders???
dram1999
I have a 2wd 1999 ram 1500 Laramie, I want to level my truck out and maybe put a small lift block in the rear. I was wondering if I could put shock extenders on the front to lift it up???
Merc225hp
NA
truck
gas
Shocks do not support the vehicle all they do is control wheel bounce and jounce. So to lift the front of your truck you need coil-spring spacers or new coil-springs.
Johnn123
Ontario
Shocks do not support vehicle all they do is control wheel bounce and jounce. So to lift the front of your truck you need coil-spring spacers or new coil-springs.
This, both are good options for what you want to do.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
^I'm with those guys. Only reason you'd need extenders is if you're destroying your stock length shocks.
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
Once you level the truck, doesn't that cause the shocks to extend fully during travel? Therefore you need the extenders to put them back into spec? Usually they don't extend fully.
Johnn123
Ontario
Vast majority of people just use stock length when leveled. You'll be fine.
Orca
