Thephpguy
I just replaced my clock spring in my 2012 Ram 2500.
The ESP light is now on and Cruise control doesn't work. I think this is normal.
I have a Innova 3160rs scanner tool that appears to have a SAS caibration on it. It is failing.
You can watch me do it here:
The end error I am getting is:
"Unable to clear ABS DTCs. ESP Sensor Initialization failed."
I have tried this a number of times with the same result.
I have tried it without manually clearing the codes and then I manually cleared all the codes and tried it again.
I am working with the latest firmware. 2022. I downloaded and updated my scanner firmware last night. (4/26/2022)
Am I doing something stupid here?
Is this scanner not capable of this?
Is there maybe a cable not seated correctly?
Thanks in advance.
Steering Angle Sensor (SAS) reset fails with Innova 3160rs after replacing clock spring
Steering sensor reset (SAS) fails with Innova 3160rs after replacing click springThe end error I am getting is:"Unable to clear ABS DTCs. ESP Sensor Initiali...
www.youtube.com
Thanks in advance.
