steering wheel pulling tick
MoparFin
U. S. Navy Vet - AS1
PA
I was driving the other day and noticed a weird tick in the steering wheel. It will pull suddenly to the right 1/8-1/4" really quick, then returns to where I was holding it. It doesn't matter what speed I am driving, if I am going straight or turning, no noise when it happens, and is sporadic. It could happen every 10 seconds 3-4 times then won't do it for 5-10 minutes, then do it once, then not do it again for another 15 minutes.
Truck is a 2018, 4x4 Express. Lifted 2 1/2" front, 2" rear, 35 x 12 tires on 22" wheels.
jws123
nj
It could be a alignment issue or a problem with those ****** electronic steering racks newer rams have if you scan it any codes?.
RamCares
n/a
n/a
Sorry to hear you are experiencing this, we certainly understand why this would be concerning. If you end up addressing this with your local dealer, please let us know via PM. We'd be more than happy to provide you with an additional layer of assistance for that process.
Callie
Ram Cares
MoparFin
MoparFin
PA
I can tell from the way it feels it shouldn't be an alignment issue. If this makes sense, the twitch feels electronic. Its snappy. No codes. My truck loves having issues with no codes, lol.
MoparFin
MoparFin
PA
Callie
Ram Cares
I can guarantee I will not go to my local dealer. They are complete idiots for techs.
jws123
nj
If i remember correctly I think possibly somewhere down the line there was a TSB about a software glitch for the the steering even tho the dealers are idiots you should ask about this or find a really good local shop that is familiar with rams.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
That'd be unsettling to drive. While the amount of movement you described isn't much, until it's diagnosed you can't know it won't evolve and get worse unexpectedly. I don't think I'd be driving that truck very much until you know what's going on.
MoparFin
MoparFin
PA
I'll tell you guys why I don't trust the techs at the local dealer. This dealer is 5 minutes from my house. They had my truck for a MONTH because the radio and dash was staying on after shutting the truck off, opening and closing the door. So it would kill the battery. Along with that, I knew this was going to happen because the stereo would stop playing all sound no matter what input was used. They had it, like I said, a month. They couldn't find anything wrong with it. The day I brought it home, the stereo stays on. I disconnected the battery. Shortly after it happened again, so disconnected battery. Replaced headunit and it has not happened again.
My 2012 Charger was having an issue where you would be driving, it would go into neutral and dash would say place shifter in park. Once you did that, it would not go back into drive and you have to shut the car off. Once you shut the car off, it won't start for 5-10 minutes. This happened 3-4 times in about 5-6 months. My daughter is driving the car for college almost 2 hours away. Take it to the dealer, they say it needs a new transmission. They buy out the unlimited warranty I have on it and say the warranty is done. I use the money towards a used transmission with 80k on it, lifetime warranty on parts and labor through the junk yard. They install it along with some other new parts. Drive it about 2 weeks and the same issue happens. Another 2 weeks, happens again. Take it back to dealer and they say there are no codes so they can't diagnose what the issue is. To my knowledge, the first time it was there, there were no codes and when they drove it, it did not have the issue. They decided that it needed replaced when they dropped the pan and looked. This time, same events, can't figure out what's wrong. So now I no longer have the unlimited warranty and have a car that may or may not shift when its supposed to.
When the trans was replaced they said that they noticed it would need control arms on both sides for inspection when it came due. I did not have them replace them.
Icing on the cake. I have take the car there for inspection since 2016 when I moved back to PA. There has been a small crack in the windshield in the very corner by where the inspection stickers go since they started inspecting it. No where near your line of sight or the area that PA says if there is a crack it fails. This year, the new service manager I am dealing with for this, sends me a text saying he can tell me right away it will fail for that crack and it needs a windshield. I picked the car up, paid $150 for them to say that they couldn't find anything wrong with the trans and took it somewhere else that inspected it no issues. Didn't need control arms. Needed absolutely nothing.
There is another dealer that is 45 minutes away, but is part of the same dealer group. I have bought 2 vehicles from them. I can take it to them as they are a little better. But only a little better.
JustinRam1500
