I have a 2006 Ram 1500 with Hemi 5.7 engine. When going over ruff road with potholes I would get a red lightning bolt light come on the dash and the engine would go to idle. If I shift into neutral I can turn the ignition off and restart and it would be fine till I hit another bump in the road. BTW this is not off road either, we just have bad roads in AZ. The code that comes up is P0522. Also after it happens and I shift into neutral the rpms will go up and down all by itself from 1000 to about 1400 rpm's. Several people I have talked to mentioned a throttle position sensor but the 5.7 doesnt have one. I went to the auto parts store and gave them the code and they did a search and said a possible fix would be to replace the crankshaft position sensor which I did but still have the problem. This morning it died completly after going over a ruff patch of road which it has never done before. Any suggestions would be appreciated.
Tony
Tony
