nursenick06
- Aug 28, 2017
- 11
- 9
- 2013
- HEMI 5.7
Here’s an update to an issue I’ve been trying to figure out. After doing some digging, I found that the passenger side stub shaft (and of course the CV joint splines too) was almost completely stripped and that end of the CV joint was flopping around on the stub shaft. It wasn’t even close to trying to grab and wouldn’t stay seated all the way on the shaft because there was nothing left to grip. Hence the clunking noise and vibrations felt in the steering for awhile.
The problem is that you can’t buy a passenger side shaft for 2012 and up front differentials (don’t be fooled by CarID, who offer a driver and passenger side, which are exactly the same item from them and definitely NOT the correct part for the passenger side.
I definitely did not want to sink money into a brand new differential, so I purchased a used front diff from a wrecked 2014 with about 22k on it for about $370. The mounting ear was broken off from the passenger side, so I planned on either cutting it off mine and welding up on the new one, or digging into mine to see how the passenger side goes together and potentially just using my passenger housing on the newer diff with the newer diff passenger side parts. I opted for the latter after I took my passenger side off and saw how ridiculously simple it is. Unlike the driver side stub shaft, which you can just pull out with a few taps of a rubber mallet to help, the passenger side is retained in the housing with an internal snap ring that rides against a bearing mounted on the shaft. To get it out, you have to remove the passenger side housing and 4x4 locker to get it out. Here’s what it looks like apart:
The hardest part was getting that heavy duty snap ring out, which was even harder to get back in. Your standard snap ring pliers won’t work, so I ground the tips of a set of long 45 degree double-jointed Vice Grip pliers to fit the holes and they worked fine for that.
I got it back together, put new black RTV sealant on, and reattached to the pumpkin. After a 24hr cure, I refilled the diff and got my truck put back together. I also replaced the driver side stub shaft (it was removed and didn’t come with the new diff), and hubs and intermediate shafts on both sides (Timken hubs and ShurTrac shafts). No more noise and vibration, and I actually have 4x4 again!
Now I’m wondering why the hell we can’t buy passenger side stub shafts from the dealer (or elsewhere for that matter)? I get it that it’s not as simple as the driver side, but it’s not a “non-serviceable” part as FCA likes to claim it is! I actually could have avoided pulling my entire diff out - a PITA in itself - and just drained and pulled the passenger housing off and kept my diff in place instead. Of course now I’ve got a low-mileage diff for a fraction of what a new one would have cost, and no labor cost besides my sweat equity and the small fortune I had to put in my swear jar getting everything unbolted, hubs off, etc!
Anyways, just in case anyone runs into this problem, now ya know. I couldn’t find much info on it other than that us 4th Gen folks were screwed if it was a passenger side issue, so figured I’d at least give it a whirl.
