Stuck at work right now please help.
Rampitt
So I get in my car to start it and it won't start. The engine is turning but it just won't start up just turns. And battery is strong any ideas?
Sent from my LG-H901 using Tapatalk
Rampitt
Rampitt
269d5d0511192216c31459b5a9c29060.jpg What is this light?
R/T_Fire
Pleasant Grove
Throttle Control Warning Light
I have a feeling your go fast pedal is bad, had this happen to me on my 07, replaced the pedal assembly and all better.
Unfortunately there is not road side fix unless you can get to the parts store and buy one and test it out... They are expensive if I remember so it might not be a part you want to just buy if its not the problem
Edit, after looking at the parts list for autozone may just be a TPS throttle position sensor, only $40ish bucks.. no whole pedal assembly on a 05.
sbarron
Wasilla, Alaska
Lol. This^^^. R/T types faster than me.
Rampitt
Rampitt
The light goes away after like 10 seconds.
R/T_Fire
Pleasant Grove
Not sure the exact model or specs of your truck but the first place I would start is the Throttle position sensor. Most likely the culprit
Rampitt
Rampitt
Well this sucks
woody31
texas
4.7 Special Service Vehicle
Any codes???
Rampitt
Rampitt
You know what I remembered what has happened before like 2 times before the truck would just shut off at idle. Randomly. But other than that it rarely did it. Drove it for lunch started and everything with no issues.
Rampitt
Rampitt
well getting it towed home now.. gonna try flashing the superchips back to stock see if that does anything. can superchips do anything to cause the truck not to start?
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
That light comes on everytime you start and then will turn off. I doubt that is your problem. Can you hear your fuel pump running when you turn the key to on? If you don't hear it running check your fuse in the TIPM and check the voltage to the pump also.
Blackram
I had that happen once, the plug in the throttle body came loose. Plugged it back in and the light went away. It could also be the sensor on your accelerator.
Sent from my SM-G928F using Tapatalk
Rampitt
Rampitt
Turns out it was the fuel pump.
Rampitt
Rampitt
:happy107:+1 for me!
I ended up spraying starter fluid in the TB and saw it was cranking up. So I then go a rubber mallet and started banging on the fuel tank and boom started right up. turned it on and off and now its working. but I gotta change that pump asap!
