Stuck distributor rotor
Discussion in '2nd Gen DIY' started by Eliwab22, Nov 29, 2016.
  1. Eliwab22
    Eliwab22 Junior Member
    27
    May 24, 2016
    Iowa
    Ram Year:
    1998
    Engine:
    Magnum 5.9
    The title says it all, I have a new rotor and cap, can't get the old rotor off. Any ideas?
  2. dapepper9
    dapepper9 Senior Member
    22
    4,779
    1,856
    Feb 7, 2013
    Iowa/Nebraska Border
    Ram Year:
    2001
    Engine:
    5.9L V8
    Pull harder lol. Try not to spin it. I realize it's a shitty area to try and reach
  3. Rustycowl69
    Rustycowl69 Senior Member
    858
    159
    Oct 24, 2015
    Ram Year:
    2001 ram 3500
    Engine:
    V10
    don't know the year, engine, so here's a shotgun answer. if you pull too hard you might damage something. So, if you could carefully pry down on the shaft and pry up on the rotor at the same time that might be best.
    Another last resort: Since the rotor is plastic, you could cover up the dist body with tape, and use a chisel to break the old rotor. If you don't like that idea, maybe carefully use a propane torch to soften the plastic, until it slips off.
  4. dudeman2009
    dudeman2009 Senior Member
    22
    1,398
    157
    Feb 9, 2016
    Lansing, Michigan
    Ram Year:
    2001 1500 Sport with enough electrical modifications to make my brain hurt
    Engine:
    Magnum 360
    Ivee had this happen on old chevys. Just take a large enough pair of side cutters or a cable cutter and crush the head of the rotor. Once it cracks, it will come off much easier.
    RubberFrog likes this.
  5. Rustycowl69
    858
    159
    Oct 24, 2015
    Ram Year:
    2001 ram 3500
    Engine:
    V10
    I like Duder''s idea better.
  6. 96liftedram
    96liftedram Junior Member
    Mar 27, 2017
    Ram Year:
    1996
    Engine:
    5.9 360
    I just went through the same thing on my 96 1500 4x4, just get in a good position and wiggle and pull, It might seem scary but with enough force it will pop right off and wont hurt a damn thing
Share This Page
