Musky Mike
Is there anyway to turn off the tailgate lock? I would like to be able to open the tail gate when the truck is locked.
That’s the problem, it’s when I’m outside working and I remember I need to put or get something out of the bed of the truck. I have to go inside to get the key fob to unlock the doors/tailgate. I would just like to turn it off and only turn it on when I need the tailgate locked.You could always unlock the tailgate with the key.
A locked tailgate is more difficult to steal.
Backup cam is on the same harness but inside the panel should be a separate connector. If you disconnect the electronic lock you still have to key lock/unlock the tailgateI bet you could remove the access panel on back of tailgate and unplug it. But I think backup cam is in the same harness so that may not work.
