Tailgate open light
dsurmanek
AZ
Looking for some help!!!
I am looking to install a tailgate open warning/indicator light. I would prefer the light to only turn on when the tailgate is open.
I have a tonneau cover and sometimes when I'm in a hurry, I forget to close my tailgate. I'm aware that many people say you should just know, but that method hasn't worked for me.
I would be willing to pay for a pre-built kit (can't find one), as I'm not very comfortable with electrical. However, I'm sure I could figure it out if I absolutely had to and somebody had a good DIY with pictures.
Thanks!
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Ok you would need a switch that is off when the tailgate is closed. There are a few types that may do it but the ones that I would recommend is this type: SPDT Switch with 3/4 Roller Lever : SPDT Switches | RadioShack.com they are also called limit switches and can be configured to give electricity when the switch is open or closed. They are easy to hook up just 2 wires is all that is needed. As far as wiring goes all you will need is to run 2 wires. Red and black. Run them from the battery (or a switched fuse which would be better), to a light in your cab (any led light will work pretty much mounted anywhere you can see it), then out to the switch in the tailgate. Here is a basic diagram of ho to do the job:
Uploaded with ImageShack.us
I am no artist so it is very basic. Maybe someone with a bit of art skills can do a better job.
Pushrod91
Ramona Ca.
Use a door pin switch and wire it up. Be the same set up as when your drivers door is open.
Sent from my DROID RAZR using Tapatalk
D
dsurmanek
AZ
Thank you guys for the input
Wish somebody had a step by step with good pics
I honestly can't believe that no company has made a kit for this...
JJP71584
Pgh, PA
Someone on here did it, little red indicator came on when the circuit was broken...haven't seen it in awhile though
JustinRam1500
