Thinking about a new Ram 1500 - Advice Much Appreciated
NotSoFast
Flagstaff
6.7 liter diesel
I had a 2018 ED with the 6-4 bed and largely loved it. It threw a rod at 36,000 miles. That's not to say that this is a common event. The tow truck driver had never seen one before: mostly he had seen engine fires. (Ram fixed that with a recall, and the new ones don't burn anymore.)
It was still under warranty but the dealer couldn't find a replacement long block. They gave me a good trade-in price and I wound up replacing it with a 2020 2500 Cummins. About half my miles are towing. I loved the better fuel efficiency of the Ecodiesel, and it was very thrifty with the DEF. I would get the cold weather package for Colorado and the engine will probably be happier if you plug in the block heater if it's colder than 15 degrees, but it will start just fine well below zero without it.
The biggest difference between the ED and the big Cummins Turbo is the engine and exhaust braking. The CTD brakes just marvelous on grades, but that wouldn't be much of an issue if you are only towing occasionally. I had a cap on the old truck that I moved to the new one.
2019RamInSC
South Carolina
What kind of cap are you looking to put on the bed? Fiberglass or maybe one of the framed soft ones? Only asking because you'll lose some cargo capacity with one on...only a 100+ lbs. or so, but if you are looking at a Laramie it might not have a payload/cargo capacity that's very high. The framed soft toppers look cool.....one member has one and looks pretty nice.
Engine preferences....not even going into that. I don't know what creature comforts you maybe interested in, but a Bighorn with the Off Road Group option might be good to go for what you are looking to do. It has a raised ride height and On/Off road tires already.
Our A.R.E. Truck Cap came in at just under 200 lbs. And yes that impacted our PayLoad.
Bomber1955
Cape Coral Florida
I put one that folds up in 3 sections. It's strong enough to stand on if you need to. There are clips to fold it just one section, or you can open your whole bed up to put what ever you want in it. The only problem with folding it all the way up is you loose your view out of the rear window. It has worked great for me. It also allows you to lock up your bed for everyday use.
huntergreen
I would have an eco diesel if I wasn’t retired and do too many short trips. The only other that bothered me is at the time when the lifetime warranty was available, you couldn’t get it on the eco diesel.
Jim Carelas
Knoxville TN
3.6 L V6
Greetings. I am new here and am a potential Ram 1500 buyer. I am posting here to learn a little from those that have come before me.
I am looking for a vehicle capable of checking off all my boxes, and I believe a smaller full-size truck is the closest thing available. I plan to use it to commute to work, transport the family around town, and go camping in the mountains on the weekends. I also would use it to haul plywood, sheetrock, and the occasional piece of woodworking machinery. I live in Colorado, so getting around in the mountains and light off-road ability is an additional consideration. I plan to install a cap on the bed to provide further flexibility while camping. Since I don't plan to do much towing, I am most interested in fuel economy and newer safety features. I am also considering the off-road package--most of my "off-road" use would be poor dirt roads over obscure mountain passes, not rock crawling or anything really serious. My only other truck experience is a 2013 GMC Sierra--I used it as a work truck where I put 250,000 miles on it. It appears that trucks have come a long way since then.
With this in mind, I went to the dealership the other day looking to test drive a 2022 Laramie with a 6.5' bed, only to be told that most people don't opt for the full-size bed in a 1500 and that the 2500 was a better fit for a full bed. The salesperson also recommended the ecodiesel over the 6-cylinder turbo powertrain. He claimed the smaller motor would be a dog in the mountains. I am curious if anyone else here has had purchased this truck with similar intentions and would like to learn about other's experiences. I also would like to know if the stock 1500 would suffice for my mountain needs, or if the off-road package is essential. Lastly, I have never owned a diesel vehicle before. Given my needs, would the ecodiesel be a good option or was the salesman just trying to sell me an engine I don't really need? Thank you all in advance for your thoughts!
I have a 2019 Crew Cab 1500 Big Horn with six cylinder and big bed. Runs good, MPG good, pulls good in mountains or not. The Family loves it.
Scott Sanders
Winston-Salem
So
Sounds as if the sales person was steering you away from anything not readily in stock...?
jimboschnitz
3.0 ecodiesel
So you don't do any towing but you want additional cargo space with the longer bed. Good starting point so you can disregard Brian42 comment about needing a 2500 because the Ecodiesel isn't for towing. I don't live in Colorado, but I have put many miles in Western states with both my 2016 Ecodiesel and my current 2020 Ecodiesel. Comparing this Baby Diesel to the 6.7 Cummins with your current needs isn't even close. Both my vehicles average better than 25mpg highway and in the thinner mountain air I've gotten 28+mpgs. Best I've seen on this and the Ram Diesel Forum from Cummins owners is maybe 18 on the highway. As for the 5.7 Hemi, I have no experience with one personally but as this Forum can attest, very few Hemi's can even come close to the fuel economy of the Ecodiesel. Yes, diesel fuel is anywhere from $1 to $1.25 more expensive than gasoline but if you calculate the fuel cost over a long term of 50 to 100K miles, you'll save on fuel with the diesel. I calculated savings between a Hemi at 18mpg and an Eco @ a conservative 24mpg over 100,000 miles and came up with almost a $1000 in fuel savings. Other considerations are the maintenance costs, oil changes for the gasser at 5000 miles and the diesel at 10000 which are the recommended intervals. Don't know about the Pentastar but some friends have a Grand Cherokee with the V6 and make trips from MN to CO for sking and they are very pleased with it's performance and fuel economy. Good Luck. I agree with Mikeru, find a different salesman or different dealer.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Great post. But I just want to make one small correction. The recommended oil change interval for the Hemi is 1 year/10k miles (non-severe service) for 5th gen 1500's. I'm not sure where you got the 5k mile OCI recommendation number from.
ramffml
ramforum
The v6 is probably the most reliable, but it's definitely the weakest. I don't think the v6 gas is going to save you much money in the mountains. It's better in the city, but the hemi catches up and matches it pretty quickly on the highway or when the v6 is working hard (mountains or towing).
The ED does sound like a good fit for you if you don't want the hemi. But I'd stay away from the 4th gen rams with ED, that diesel has had too many issues related to both emissions and main bearing failure. Most do "get lucky", but why take the chance.
06 Dodge
Forest Grove, Oregon
6.7L CTD
FYI the 2022 6.4L OCI is 1 year or 8,000 miles with some dealers recommending 5,000 OCI....
archer75
oregon
6.7 CTD
I'm kind of in the same boat. I may custom order a 23' 1500 crew cab with the long bed. Laramie. Loaded. I currently have a 15' Ram 2500 with the diesel and am currently pulling a travel trailer but we're planning on selling the trailer so I won't have any need for the larger ram with it's cummins. The only issue I had is the turbo actuator went out which was a $4k repair. A year later I got a letter in the mail saying they've extended the warranty on this part and wanted to refund me the cost of the repair. And they did. Never had any emissions issues with it. I've done all my oil and fuel filter changes myself.
I don't really need an ecodiesel though the mileage is nice. Not opposed to the 5.7 hemi. Also curious about the 3.0l 500hp hurricane next year.
I'm also considering an F-150. I have no brand loyalty.
jimboschnitz
3.0 ecodiesel
For Mikeru, the 12 month or 10.000 mile that you quote as the recommended is actually stated, the 12/10K interval should never be exceeded, it is not the recommended interval. Actually I was incorrect however with the 5000 mile statement. Oil changes are supposed to be done when the change oil indicator lamp comes on.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
You're absolutely right. My bad for using the wrong word. The owner's manual states to never exceed 10k/12 months. My point was that the OCI is not 5k miles. I change ours once a year, staying within that 12 month period. Since we only put about 5k on our truck each year, we're well within the 10k mileage limit.
ramffml
ramforum
Personally I'd never ever wait that long. Best bet is at least once a year, or every 7000 miles (drop it to 5000 for heavy towing or lots of idling). The indicator is a formula that somebody else wrote based on a bunch of variables that the truck collects, it's not all that accurate as far as I know.
CaliRamDude
San Diego, CA
I have a 17 1500 hemi and regret not getting the 2500. Then you can really tow some stuff. The 1500 is severely limited in its towing capabilities. You should never really go past 50% of GVWR. Which on any 1500 is basically lowest in its class. You’ll end tail wagging the dog. Or you’ll be the guy with his rear end half way to ground
CaliRamDude
San Diego, CA
well I'm guessing that no-one told VernDiesel's EcoDiesel that it can't tow. His has over 900K miles mostly towing Airstream trailers across the country and a buddy of his has an EcoD with over 400K doing the same.
I've had an 8K lbs 32' trailer behind mine several times and it does a great job towing. Two fingers on the steering wheel with the cruise set, stable as can be and lives up to it's "eco" moniker fuel wise. Pulled the trailer 250 miles and traveled back 250 miles empty on less than 26 gallons of fuel(capacity of my tank).
Wow man sounds super risky. Just saying
CaliRamDude
San Diego, CA
Don’t forget to throw in the lifetime supply of rubber gloves you’ll need filling up!
Stavinksi
Midwest
May I suggest you look at a limited or longhorn. For the price of a fully loaded Laramie you are ~ price parity and all that comes standard. Interior is much nicer and resale will likely be higher. F150 interior, even platinum trim, just feels cheap even compared to a Laramie trim in my opinion.
archer75
oregon
6.7 CTD
I can't stand the longhorn interior. And I don't care for the limited interior either. The colors and stitching. Just not a fan. Otherwise i'd go for it.
Wally Koeberl
Dowling MI
