Dougiefresh2012
i noticed that sometimes when i start my truck there is a ticking noise it’s pretty loud. But only ticks half a dozen times at most then stops.
Anybody know what this is?
See your point. When you have the time could you tell us what grade bolts were used to correct the problem.There is no such thing as a “Hemi Tick”.
That phrase was coined by Chrysler to avoid having to replace exhaust header bolts. The header bolts on every Hemi are inferior and have an issue with temperature related torque settings. While nothing will happen to your truck in the short term, in the long run, the header bolts will snap from constantly being too loose/ too tight with temperature change. There’s a TSB for this issue. I replaced all my header bolts with the new improved ones along with new gaskets. It’s a big job, but after install and proper torque....... the “Hemi Tick” no longer exists. I was lucky enough to replace the bolts before they snapped, and that’s key!!! I replaced my bolts at 70,000 miles. I’m now at 104,000 with no ticking.... ever. Do not wait until they snap!!!
