Tire size on a 2500?...
bigbadram1500
Springfield, IL
I went from a 33 to a 34 and it threw mine off by 2 mph. I believe some of the tire websites have a calculator to determine the difference. I'll see if I can find it for ya.
bigbadram1500
Springfield, IL
Found it :)
(New Tire Diameter / Original Tire Diameter) X Indicated Speed = Actual Speed with new tires
archerr2002
archerr2002
East Liverpool, Ohio
Will it make the speedo slower or faster? I am going to be putting these tires on the stock rims. I figured going with the 285 will have less chance of rubbing than the 295 or 305's
Stangshcky12
Oshkosh, WI
5.9 Cummins
Let to this one
285s won't throw it off to bad, itll be 3.5% to slow, so more noticeable at highway speeds
When your speedo says 60 your really doing 62.5
35s will cause it to be 10% off
285s fill the wheel well out great on quad cab short beds but still look tiny on quad cab long bed
Stangshcky12
Oshkosh, WI
5.9 Cummins
I wanna say 285/70/17 dynapro mt. I'm at school so I can't check. 285/70 is a more typical tire size, more opting for less
285/75 will fit with out any problems to
If you go with the 285/75 you'll be closer to 7% slow on your speedometer
Off topic but how far from wellsville are you, I've ride. Dirtbilkes ou there a few times alot of nice hill climbs
archerr2002
archerr2002
I finally got the Nitto's. 285/75/17 and they look awesome. Plenty of clearance and make the truck look way better than with those little 265's. I ordered them from tirebuyer.com and got em for $850 installed.
Mega-Hemi
US AIR FORCE '08-'18
Back in New York!
I love my NITTO Terra Grapplers. No noise at all, great wear pattern. I'm running a 275/65-20 which comes out to about a 34" tire. I have a little rubbing at full lock if I hit a bump but I think that's just because of the offset of the wheels. On stock wheels I don't think they'd even come close to rubbing.
quietpeen
2021 TRX
Hellcat
you can definitely fit 35's, don't know if the width would be a problem(is that on stock wheels?)
Rlistro2010
stock 17" rims. I need to know what widths will not rub so I don't waste money lol
