Torque converter question
Dodeman
I have a 95 dodge ram 1500 4wd. Its an auto trans. Here is the question. It started yesterday after I drove it up the interstate. Well when I go to take off from a dead stop it will move slow and the rpms jump up to about 2200 before it starts to move. Now when I pull the shifter down to 2nd it takes off a little quicker. It will not shift from 1st to drive it stays in drive and it won't shift into over drive eiter . I just replace the trans about 3months ago and it seems fine. Now once I put the truck in park it jumps a little forward. It will catch and back up great but don't have no power to turn the tires over in drive unless u put it in 1st but u can tell it dont shift expect from 2nd to 3rd. What could it be?
MagSport
South Carolina
Is it throwing any codes? It sounds like a governor pressure solenoid not working/hooked up right.
D
Dodeman
Its throwing codes. I have to get the code numbers to see but what's the best place to look online for them
LilRamie
Atlanta GA
If just had tranny replaced, have u tried going back to the shop for a checkup to make sure its all okay as it should be? My older vehicle I had aftet new tranny I had to bring in for reinspect to maintain its new warranty.
Sent from my SPH-L720 using Tapatalk
Joey93
