Torque Wrenches
2011 Ram 1500
I am installing my headers soon and it calls to torque wrench the bolts on the engine to 18ft/lbs. So from never using a torque wrench and knowing nothing about them, I bought what I thought was right. The torque wrench only goes up to 14 ft/lb so it is possible to torque it to 14 and then to 4? or do I need to return it and get the bigger one.
charonblk07
Calgary, Ab
F1-A forged 349ci
You need a bigger torque wrench, one that goes higher than 18ft-lb. The best example of what you are proposing is having one person climb halfway up a ladder and a different person climb the rest of the way.
Beauregard7765
2011 Ram 1500
I have the smaller one of that, but the package had 25-250 in inches so it threw me off.
Beauregard7765
2011 Ram 1500
It wouldn't be this would it?
Sent from the fetal position using Tapatalk
charonblk07
Calgary, Ab
F1-A forged 349ci
If that's the torque wrench you have then it's sufficient to do the job. 1ft-lb = 12in-lb so if you need 18ft-lb you turn it to 205 +11 in-lb. To do that, turn it until the 0 on the dial is at the 205in-lb mark where the horizontal line meets the center line then turn it until the 11 is on the center line and you're at 216 ft-lb.
alexalex
Hello folks!
Sorry for retrieving this thread. I am new to this forum and need a reliable torque wrench.
I'm having trouble finding one that isn't $100+ USD.
Any recommendations? What are you guys using out there?
While I was surfing the web, I found this https://mechanicguides.com/best-torque-wrenches/ nut some real experince would be highly appreciated.
Skubasteve!
I purchased a husky brand one from home depot many years back and it has been great for what I needed. It wss around $70 if I remember correctly. It was better than the craftsman/HF ones at the time. Its a nice unit for the price. Just make sure with whatever wrench you get, that you zero it out after each use to relieve the tension.
Its on sale right now too.
https://www.homedepot.com/p/Husky-50-250-ft-lbs-1-2-in-Drive-Torque-Wrench-H2DTWA/205914009
HemiLonestar
MD
Just remember, with quality tools, especially special tools you get what you pay for.
donno21
Las Vegas Nv
Cummins Diesel
When I was working as an A&P one of my extra duties was monitoring company tool calibration. The calibration folks claimed HF torque wrenches were as good as any.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Check out Tekton torque wrenches on Amazon. I use mine (1/4, 3/8 and 1/2) regularly and am very happy with price/quality. Agree with earlier post of zeroing out after every use. That is sound advice.
G. Mcpherson
Yacolt, Wa.
2023 Ram 2500 CC SB Tradesman
I use Proto Wrenches. One is 3/8 up to 90ft. lbs. The other is 1/2 up to 250 ft. lbs. Found the Tekton on Amazon for under 40.00. 3/8 drive up to 150 lbs. Smaller and works well. Looks to be well made.
12vrunner
Texas dfw
Any one expirence kobalts toque wrenches from lowes. Our torque wrench calibration guy at work said they are good.
panoz3
Waterloo, IA
I also recommend Tekton. They are very well made for the price, Amazon is a good place to look. They also come with a nice plastic case for storage.
Sent from my XT1030 using Tapatalk
-B-
Northshore of Boston
Keep in mind many consumer and truck brand torque wrenches are only useful for a percentage of scale , ideally you want what you are going to torque in side that range close to the milled of said range. For occasional use one or twice a year or so Craftsman, Kobalt, Husky and even Harbor Freight are all just fine for the job. All of those brand I just mention will hold good accuracy for quite a long time if taken car of well. Personally in what I do I have top end industrial torque wrenches some days that get used 100's of times a day. I also will not buy a torque wrench that does not have use of 100% of scale and does not hold accuracy to +/- 3%. If you want to see my preferred brand check out http://www.bestool-kanon.com/items/list.htm the best par is the pricing of these tools they blow away tool truck brands.
As for differing styles:
beam types are just fine for many auto motive applications and are quite cheap these days,
click type are also just fine and also on the bargains side if you stick with the previous brands listed
split beams are at the top end and are over kill unless you are doing engine builds, trans , or rear end work that need the precision and repeat-ability
tourrider
Grumpy
NW PA
CTD 6.7
I have this one, as well. It’s a decent basic Torque Wrench that should get the job done. Granted, I bought mine during a Black Friday sale, it was $30.
This^^^ Unless one is working on payload for space flight, a couple of Craftsman click torque wrenches will serve you well.
1 @ea 1/2" drive FT pound
1 @ea 3/8" drive IN pound
You'll need a smaller 1/4" drive if you do any pinion work.
I've been known to break out my Craftsman beam that I have owned for 42 years. It goes a little higher than my click wrench.
Sent from my SM-G935V using Tapatalk
01Ram2500
I agree that for the price, a Craftsman wrench should do the job. xeriminox stole his for $30. Amazon price is currently $74.
https://www.amazon.com/Craftsman-9-...115&sr=8-5&keywords=craftsman+torque+wrenches
Can't have too many torque wrenches in my view. 3 of my 5 are Craftsman. My oldest is almost 40 years old. The quality back then was markedly better than today's offerings. Many of my old Craftsman tools were made in the USA. They last forever.
