Depends on what you are pulling. There are all kinds of holes and brackets that you could use. I may have miss read your post now that luke mentioned it. If you are recovering a vehicle frame, frame, frame. You will most likely rip the bumper right off if you try to pull from it. Usually anywhere on the fram is a good idea as long as there isn't a chance of the strap or chains getting bound up in any way.
