Towing with a D150
Discussion in 'Towing & Hauling' started by Matteo, Jul 16, 2015.
  1. Matteo
    Matteo Member
    41
    10
    Dec 20, 2014
    Calgary, AB
    Ram Year:
    Engine:
    so i have a 1989 D150 and was thinking about possibly towing my jeep down to Moab this fall.
    i have a class 3 frame mount for pull behind.
    i also noticed, the previous owner had a fifth wheel hitch installed.
    are there benefits to the fifth wheel capacity wise?
    My jeep weighs in at 4815lbs.
    what are your thoughts on towing. looking for some insight on this topic as i have never really looked into it. trying to do my research but i know there are people out there that have this nailed down.
    Thanks!
  2. crazzywolfie
    crazzywolfie Senior Member
    14,160
    2,154
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i don't think you can legally haul your jeep with your truck just because your truck would not weigh enough and the jeep most likely weighs more than the class 3 hitch is rated for especially when you add in the weight of a trailer. i don't know as much about the 5th wheel hitches but i think if you used one you would be closer to being legal than a tow behind trailer.
  3. JJEH
    JJEH Senior Member
    228
    40
    Dec 11, 2012
    Tornado Alley, OK
    Ram Year:
    2003
    Engine:
    4.7
    I believe the D150 had like 4,000lbs with the 318 and 6,500lbs with the 360.
    Your Jeep weighs in @ 4,815lbs according to you + ~2,000lbs(?) for the trailer.
    A class 3 hitch has a weight carrying rating of up to 5,000lbs GTW.
    So I'd not consider it.
    A 5th wheel or gooseneck hitch only distribute the weight directly onto the vehicle frame. They do not increase your GCWR!!!
    ferdamshur likes this.
Share This Page
