TPS & misfire issues due to parking on hill!?
tinkerbotstl
v6
Howdy all,
2015 Ram 1500 3.6L
Parked on a very steep hill leaning to the front passenger side for a few hours, when I started truck it immediately started running really bad stuttering, vibrating, and throwing these codes
P0304 powertrain cylinder for misfire detected
P2311 powertrain ignition coil D secondary circuit
P0223 powertrain throttle position sensor circuit high
Thoroughly checked tps/throttle body and connector with meter, cleaned, tested for intermittent operation due to vibrations and found none, Reset tps
Tomorrow will check cyl 4 coil & plug.
Any ideas?
Ftank
