mondo
- Aug 4, 2014
- 954
- 482
- Location
- Columbia, Pa
- 2014 2wd express rcsb
- 5.7
I installed a headunit with the maestro a couple months ago. After install, i had the traction control light on all the time. I thought maybe it would clear after a few key cycles. Well no luck and its been alot of key cycles...lol. I decided to install the factory one to change the settings for unlock, headlights and accessory time. Figured id start it up WITH the harnesses plugged into the dash controls. Now the traction control light does not come on which is a plus. Just wondering of when i did the install, when i checked to see if headunit all worked before buttoning up everything. I turned on the ignition without the 3 dash plugs plugged in. Wonder if that had anything to do with it. Any insite would help.
