- Oct 26, 2015
- 534
- 505
- Location
- Larkspur, CO
- 2016
- 6.4L Hemi
Hey all, I am hoping someone can advise before I have to take my beloved to the dealership for tranny work.
2016 Power Wagon w 58K miles on the clock. Only once have I ever had any significant problem and it was with the trans at approximately 40K miles -during interstate travel trans dropped into Safe Mode / Limp mode at which point I had the TSB for a trans solenoid completed. Aside from that, and a few nuance items the truck has been nothing short of perfect.
I started noticing tranny slip, delayed start from a stop, in heavy, hot stop and go traffic a couple weeks ago. I immediately checked fluid level, 3/4 qt low, I added the same to bring level up. No change. Trans still slipped on starts. I did a oil and filter change, a pan drop but I let it drain for a good amount of time also lifting the front end with a jack in order to drain the TC as much as possible. I drained and replaced 9qts of ATF+4 fluid. The slip improved significantly but I still detect slip on start - maybe even intermittently, sometimes the slip is no doubt, sometimes I think its fixed but then it slips happens again.
Mostly stock, CAI, pedal commander, Trinity T2 (canned tune until header install which will happen immediately upon tranny fix) magnaflow catback, 35" MTs, I baby the crap out of her until we need WOT.
Any suggestions on what I am looking at or could possibly do to correct would be greatly appreciated.
The magnet was covered with a light gray film, as was the filter and inside of pan but nothing gritty, the outside of the filter and the magnet were covered nearly the same, the magnet had only slightly more gray film covering it then the filter, and the smell was the smell of clean synthetic, the color was just a shade darker in the old oil compared to the new Mobile 1 ATF*4.
Any other info I can provide please let me know. thank you again
