badfish888
- Jun 27, 2010
- 1,092
- 89
- Location
- Va beach
- 2012 hemi express
- 5.7L Hemi
The school im at for the next few weeks has a shop with lifts for use. I figure this is a good chance do to my trans filter and fluid change.
Buddy just did his 07 ram And said the filter kit (both filters, and trans gasket) Was under $20 at pepboys
I usually like to use mopar when i can.
Does anyone here run other than factory filters. And what about the fluid. Should i stick with mopar atf4
Or will i be ok With a castrol atf4
From what i understand When i do the pan drop A small amount stayes in the converter. So i was u sure about mixing.
Also about jow much fluid is required for a pan drop and filter change
