Check volts on your battery below 80% could not be getting right amount of volt signal to the trans and if its a 8 spd trans you could check fluid level when temp is @ 100* if its good
find a transmission shop let them reflash your trans and drive around for awhile.
Light on the pedal while trans is relearning
fluid looked fine I’ll put the multi meter to the battery and look at that thank you for the advice
