Transmission Pan Leak Diagnosis
Jocephus86
Marietta, GA
I just purchased my 2016 Ram 1500 Tradesman from a dealer. Naturally, as soon as I got it home, I got a misfire (fuel injector, which the dealer paid for) and had to change out the front lug studs and all lug nuts.
After this was completed, I noticed an oil leak. Crawling under the vehicle showed that the oil was dripping from the torx bolts holding the pan. Additionally, just forward of the pan is another pan, much smaller. I think this is the cooler, but not sure. I'm new to Ram trucks.
The pan appears to be nearly new (the dealer assured me he had not changed this).
I attempted to snug the bolts around the pan, and (rookie mistake) I broke one. I'm getting it replaced in two days.
I'm trying to determine the best method of troubleshooting and repair, without breaking the bank.
1. If the leak still persists, I'm considering removing the pan and replacing the gaskets, reusing the fluid (after filtering) if it appears clean and original color (not sure which oil they used). My concern is that I will still have to add more fluid, and I don't know what was used.
2. If #1 not an option, bite the bullet and change the fluid and filter.
Update - Bit the bullet and replacing pan, gasket, bolts (one is broken - easy out) and fluid.
Thanks for the help.
Joe
ThunderMug95
North Prince George, VA
I am betting the pan is missing the flange collars for the bolts if its dripping from multiple bolts. I have intimate and recent knowledge of this pan. I did a pan swap and fill Saturday.
Also filter in Mopar pan is built in, not replaceable…You have to buy a new pan.
If you do this its like $230-250 for the pan. Or you can spend a bit more and get one of these like I and many others did.
There is also a very specific way to fill and verify fluid level. Its not a dump in and go.
I used Valvoline Multi ATF and its shifting great. $34.99 for 5qts at Autozone.
Or you can spring for the magical Unicorn *** that Mopar specs.
brianw0048
EcoDiesel
there’s a factory replacement pan on eBay as well…like $30.
LVnight1500
Did you have to buy the gasket separate? Or it comes with the PPE pan?
LVnight1500
ThunderMug95
You’ll also need to reuse the old bolts from the factory pan and the collars.
What @Atcer2018 said is accurate. Some have reused the gasket. The collars on the flange bolts keep the gasket from being over-compressed, so in theory it could be reusable. I chose to get a new one.
My best advice to anyone is have a solution for the pan install. The oem pan will come out fine, but the PPE will require some work. Jack the trans up by the crossmember mount (gently and slow) or drop the exhaust behind the headers.
J
Jocephus86
Marietta, GA
I resolved the issue. This was an oil cooler issue. Replaced with all an all metal oil cooler, the leak has been resolved. Unfortunately, while torquing the bolts on the pan, one failed. I have the parts and fluid to replace hydraulic fluid and pan, so I'll take care of this soon. Thanks for everyone's help.
joesstripclub
Lees Summit, MO
2021 2500 PW
Make sure you get an OEM pan gasket if you buy an aftermarket pan. I got a cheap ebay pan and had to replace the gasket since it leaked.
