U-Joint Noise?
jbrew717
Northern Indiana
2006 Ram 1500 4x4... I'm gettin a squeaking/clicking in reverse, and a clicking that is louder when i let off the gas in drive. Is it U-Joints? It would be the 2 on the rear driveshaft correct? Since the 4wd shaft doesn't spin when it's not engaged? I heard the stock ones had grease zerks but didnt find any. Any and all help is appreciated! thanks!
Cthulhu
Calgary, AB
Cummins 5.9
Sounds a lot like my U's before they got replaced. I'd say its worth pursuing.
Sent from my Tapatalkin' BB 9800
HemiBabe
DFW
Yeah, sounds like U-joints to me too, at least they're cheap :)
Cthulhu
Calgary, AB
Cummins 5.9
My dvr went, then shortly after my psgr went. So, I'd say those two.
Does the sound happen when you turn or when you are straight? In 2x or 4x?
Jcasey10
Springfield, MO
Magnum 5.9L
I would jump underneath your truck, and give the driveline a shake, if you can get any play, I'd say it's u-joints. Replacements will most likely come with grease zerts
J
jbrew717
Northern Indiana
i feel play in the rear driveshaft but none in the front. Any suggestions as to what brand to go with?
HemiBabe
DFW
I think they're all the same, but not positive lol
fonzyn75
Deffintaly replace them asap lol My rear u joint snapped going down the road long story short my driveshaft flew out and it cracked my transfercase into 5 pieces, had to get it towed home and i had to put a new t-case and driveshaft in it. And what pissed me off was the fact that it was a 30$ joint that did all that damage lol.
I would highly suggest MOOG u joints there heavy duty and i think there the best you can get
a local advance auto or auto parts store should have them
feloram1500
Well, thanks to you all. I had the same noise when backing up, and guess what???
U - Joints. :naughty::favorites13:
Joey93
