UAS Upgrade No Carplay
HoldenRam17
USA
Recently completed the upgrade from the Harmon 5" to the Panasonic 8.4"
Android Auto works flawlessly.
Apple Carplay will not.
Thought it may be a FW/SW issue but nothing I've read through states others having this iissue. INCLUDED PHOTOS just in case.
Have tried all basics I can think of or have read others experiencing connection issues with apple products.
Open to ideas!
tron67j
Maryland
Are you using a Apple data cord? Apple hardware and software are notorious for not working unless oem parts are used.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Sounds like wrong parts... Where did you get your 8.4 upgrade/conversion harness from?
Edit: part numbers are good.
Administrator
aside from what they ^^^ mentioned, which USB media hub did you upgrade to?
H
HoldenRam17
USA
I am using the one the phone came with. However I just picked up a new lightning cable today and plan to try that when I get home.
18harvest
huntsville
Is your carplay app up to date on the phone? I had this problem with android auto.im not an apple guy so not sure how their apps work
H
HoldenRam17
USA
Tried the new cable today and no luck. Did get the USB to show "iPod" but no changes.
The harnesses and bezel cam from infotainment through radio was pulled from the same truck as the media hub.
chri5k
USA
Diesel
You should call Infotainment and RMA that harness. You have the right radio, software and USB hub. They have been known to put out a stinker on occasion. Once you have a new harness post back with the results.
boblonben
Are you sure auto play was loaded in the radio???????? Friend of mine just got new truck GM - and auto,play is not installed anymore!!!!
