Upgrade Your Truck with Premium Running Boards from RealTruck!
RealTruck
Preferred Vendor
Looking to enhance your truck's style and functionality? We've got the perfect solution! This month we will be spotlighting the Amp Research Powersteps, Go Rhino RB20 Slims, Go Rhino RB10s, N-Fab Cab Length Podiums and the N-Fab RS nerf steps!​
AMP Research Power Steps- $150 off PowerSteps, $200 off Xtreme, XL and Smart Series ONLY 9/6-9/27
Upgrade your truck's look and functionality with our Electric Running Boards:
Key Features:
Automatic Deploy and Retract: No more awkward climbing – they extend and retract automatically.
Enhanced Safety: Wide, non-slip stepping surface for secure footing.
Durable Construction: Built to last, even in tough conditions.
In-Stock & Ready to Ship: Our electric running boards are available now for quick delivery.
The Go Rhino RB20 Slims are perfect if you are in the market for a new set of steps, but you aren't looking for anything too bulky! These boards feature the same raptor styling as the original RB20 Running Boards, but they are much slimmer at 5.5" the widest point vs 7.5" wide, like the full size boards. They are made from 16-gauge galvanized steel and come in your choice of textured black powder-coat or premium protective bedliner coating, both of which provide excellent protection against the elements!
The Go Rhino RB10 Running Boards feature a heavy-duty 16-gauge steel construction for unmatched strength, withstanding hundreds of pounds of downward force to support you and your passengers easily. The cab-length running boards also protect your vehicle's rocker panels, guarding against rock chips and minor impacts. Corrosion-resistant zinc plating encapsulates each running board, keeping rust at bay even if moisture bypasses the polyurethane coating.
The N-Fab Textured Black Cab Length Podium steps are built of a heavy duty stainless steel construction with a corrosion-resistant textured black powder-coat finish. These steps feature low, extra-wide 4.75-inch drop steps with a serrated non-slip surface, making climbing in and out of your truck a breeze even after installing a lift kit and oversized tires!
The N-Fab RS nerf steps are crafted from a sturdy steel tubing and protected by a dual layer powder-coating to form one stylish set of steps! The protective coating starts with an e-coat base-coating and then meticulously finished with a textured black powder-coating and fitted with plastic end caps to protect the steps from corrosion.With these steps, you and your passengers will be able to securely step into your truck with ease on the 4.75" wide die-punched step surface.The Nerf Step RS will add functionality to your ride as well as style with the rugged look of the textured hoop steps. N-Fab backs these steps with a limited lifetime warranty. MAIL-IN REBATE- Free Husky WeatherBeater Front Floor Liners with purchase! Offer ends 09/26/2023!
At RealTruck, our running boards are built to last and designed for easy installation, compatible with various truck makes and models. They offer:
Style and functionality ✨
Enhanced safety
Easy installation​
Ready to order or have questions? Simply shoot us a private message or email us at [email protected], and our forum team will assist you promptly. Your truck will thank you for it!
Upgrade your ride now! #RunningBoards #TruckUpgrades #PrivateMessageToOrder
