Want to add: 5" exhaust tips
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
How long are the tips from moes same length at stock just 5" ?
Stock tips are only about 6" long and 4" diameter. Our tips are 12" long and 5" in diameter.
Hemi_1340R
Indiana
O sweet I thought in some of the pics they were just the same as stock just 5" . You just carry them in chrome correct ?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Yes...polished finish.
SitKneelBend
St. Louis
3.6 Pentastar
12"? They don't protrude an extra 6" right? The that extra open mouth is all behind the bumper right?
In addition, do they just clamp on to the factory tail pipes in the sane fashion as OEM and remain adjustable or does this MOD require cutting and/or welding?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The added length is on the back of the tip. And they do have the same ball/socket connection as stock to make for a clamp on install. You do need to reuse your factory clamps though which will require you to grind off the small tack weld that secures the clamp to the stock tip.
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Thanks for stepping in with all the answers to questions. I hope this thread helps more member than just me. :D
Adam
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
Moes FTW :D
TRXHemi
Sugar Land, TX
I bought mine on eBay for $40 each.... they were satin black, but I did them in high heat gloss. Had the resonators removed as well when I installed an 18" magnaflow. Looks good, sounds good!
After this pic was taken, I actually painted it all gloss black all the way to the muffler.
TestPilot57
Vermont
As Moe's clarified, the "tip" is longer, but the pipe is shorter. However, while I didn't put the new next to the old before installing for direct comparison, I would say they stick out about 1/4 to 3/8" further than the stock ones.
