Want to get new wheels
Ramtruck211
Hackensack
Got myself a 2019 ram 1500 classic about a few months ago. First ram truck and new to this forum. I want get these tires shown below. They are 265/70/17. I currently have on my truck are the stock tires and rims 275/60/20. I’m not good with tires and all that how ifs it’s a bigger tire it kills your gas mileage etc if that’s even correct what I’m saying lol. I was just curious if I get these wheels would it affect anything with them being different in sizes? Please help. Thanks
XCELLR8
Central Illinois
Yes, your speedo will be off. Your stock set up (275/60/20) is a 33" OD tire and the other ones are a 31.9" OD tire.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Make sure the wheels clear the brake calipers. Not all aftermarket wheels are created equal...Some have smaller inside diameters than others.
The description says they're stock Rebel wheels so they'll fit fine if that's true. They look like the Rebel blackout wheels my wife had on her 2017 Rebel.
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So adding to that question; what is the maximum rim size to mount 275/60R20's tires? 20x?
CanuckRam1313
Ontario Canada
2023 Warlock SLT
I've got stock 20x8 rims on my 19' and I have LT295/65R20 Michelin Defender LTX M/S tires on and they fit perfectly with zero issues.
Although, I do have a full Bilstein suspension on all four corners with the fronts set at 2.1" height adjustment (OEM stock springs front and rear).
Lsujker
Baton Rouge
Your question is a little confusing. You asking about rim width? The tire manufacturer recommends a width range. You asking about backspacing for aftermarket? Wheel offset is a fantastic resource.
