Want to level my ram, noob needs advice.
Mopar775
jf5.9
In the Woods in Ohio
5.9L
I'm going to pick up Rancho RS5000 Shocks for when I level my 98 - Advanced Auto carriers it - just get the shock for 1-2" of lift.
jf5.9
5.9L
you will still need the coil spacer - you will also need the longer shocks - and an alignment -
crazzywolfie
under the truck
do you use your truck as a truck and haul weight in the bed? if so leveling the truck will make your truck look silly when you actually put any good amount of wight in the box.
Howells
Kitchener Ontario
5.9L
Your factory shocks will work. I had a 2.5 inch spacer on mine awhile back and the factory shocks worked.
JJP71584
Pgh, PA
I have a 2.0 HBS level on mine with the stock shocks...no problem and no complaints
Sent from my SPH-L710 using Tapatalk 4 Beta
