weird problem NEED HELP
Discussion in 'General Discussions' started by Scottlanham, Jan 7, 2017.
  1. Scottlanham
    Scottlanham Junior Member
    Jan 7, 2017
    Ram Year:
    2002
    Engine:
    Magnum 5.9
    First of all, my dodge won't shift down into gear 1 at all
    Second of all after going out of 4wd my truck will not go into park
    Does anyone know what this could be?
    02 Dodge Ram 1500 4x4 SLT
  2. Ram Lover
    Ram Lover Senior Member
    42
    393
    127
    Jun 12, 2015
    Maine
    Ram Year:
    2002
    Engine:
    5.9L 360
    Not sure about the 4x4 unless it's related to problem number 1, does first work if you put the shifter in first? It could be your shift solenoid, mine did that after I changed the filter and fluid it sucked up crap and had to do it all over to change the solenoid, but check the simple things first, fluid full, does it smell burnt? Change fluid and filter, then if possible a good transmission guy should be able to tell you what's up, and maybe scan it, the guy I use scanned mine and in 2 sec told me the solenoid thought the truck was going 10 mph in park.
    Sent from my SM-S320VL using Tapatalk
    usaf2006 likes this.
Share This Page
