- Dec 19, 2017
- 732
- 590
- Location
- La Center/Amboy, WA
- 2017
- 5.7 Hemi
Tire specs...if the first were not specific enough
Sent from my SM-G950W using Tapatalk
OK, so your latest pictures show a totally different spec and tire from your first screenshot. LT (Light Truck) is different rubber compounds, weight rating, sidewall/tread thickness from P (Passenger car) rating.
That said....I recommend starting at 50 front, 45 rear and adjust to your liking.
BFG generally recommends minimum 50 psi in your situation.
I run E-Rated (10 Ply equivalent) Nokian tires at 50f 40r and for summer time will be bumping both by 5 PSI.
Higher PSI will net you better MPG, more responsive (albeit possibly lower total threshold) cornering, higher weight carrying capacity with safety, harsher ride, possible center tread premature wear (depending on how high you go, chalk test will get you best contact patch, ergo best wear characteristics).......
