What needs to be replaced with a new engine?
Bryce Kircheis
It finally let loose, 2014, 2500, 189K with a 5.7, Rod Knock, metal in the pan.
I'm in the process of pulling the motor, most likely going to be a reman replacement.
What needs to be replaced with the motor. I have some of the basics, but is there anything else?
Plugs
Water Pump
T-Stat
Belts/Hoses/Tensioner
Can the oil cooler and intake be cleaned?
What about the VVT solenoid?
Other items/sensors?
Plugs
Water Pump
T-Stat
As long as the engine didn't blow up,the intake should be clean-able,i spray them down with degreaser on the inside,remove the short runner valve motor on the back of the intake,then wash the living hell out of them at the local coin-op carwash,then blow it out with compressed air once i get it back home.If your truck has an oil cooler,i'd probably replace it though.Depending on how much metal is on the VVT solenoids screen would determine whether it needs replacing,if it's clean i'd keep it,if it has a build up of fine metalic particles,i'd replace it
Ftank
