when i turn left into my driveway truck shuts off
outdoorram
Vermont
just got this 1996 2500 reg. cab pickup it has the 360 and is auto. now the strange problem when I brought it home 2 weeks ago and turned left into my upper drive way it shut off it did start right up . I've been cleaning it etc. and my son took it down to the store truck was fine . when he came back and turned left to pull into yard it died just like before it did start right up again . anybody have this happen to them ? or does anybody know what it might be ? thinking a short or ground wire ? but whats strange is if its a short I would think it wouldn't start up again unless something got moved like the truck . any help on this would be great , Thanks
SilentRon
Well, at the risk of being a real Beavis, I could ask if you've tried turning right into your driveway. Seriously though, is your truck setting any trouble codes or tripping the check engine light?
preachp
The Con State (CT)
Hi outdoorram,
Look at your motor mounts and for an arc spot on the metal around the alternator and battery. I had a 71 Sport Fury that did that going right. Turned out one of the motor mounts was shot and the alternator was hitting against the inner fender well when I turned right and touched the gas.
Hope you get it sorted.
preachp
Orca
