Where Can I find SOLID engine mounts?
Josh22855
Does anyone know where I can find a set of Solid engine mounts for a 2016 Ram 1500 single cab? I have searched and searched with no luck.
I do not have a Facebook so I am unable to poke around on the high performance ram page.
Any info is appreciated.
Thanks.
Thanks.
I don't think there's any aftermarket solid mounts for the trucks,i've never stumbled across any,and i searched for them a few years back. You could add an old school torque limiting strap/chain on the drivers side if you want,as it's the drivers side mount that takes the most abuse on a hard launch.I added a chain and turn buckle on my truck,and just run it so the chain is just snug.
Josh22855
Josh22855
Thanks for the info, I may go this route and also fab up something to keep the block solid to the frame.. I lost a transmission and block a few months back at the track and sadly I am still uncertain the cause of it.
Josh22855
Josh22855
No, this is the first that I have heard of them, I will definitely reach out to them.
I appreciate it!
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
I just looked at FabTech in different locations, it turns out that there are several companies called FabTech
years ago, I bought solid motor mounts for some hot rods from a local branch of of https://fabtechmotorsports.com/
there is a fabrication shop in Texas, that uses waterjets & plasma cutters, etc.
Josh22855
Josh22855
Thanks again, I got a hold of a 6.4 that is about to grow in size! I do not believe the stock mounts will be sufficient for what's soon to come.
Have you talked to Rick Spillman or Matt Fikac / Moes about solid mounts for the trucks,if anybody will know if they are available it'll probably be those 2 guys.
Josh22855
Josh22855
Matt still has/had stock, is Rick the man with the Blue ram?
Yup Rick has the lightweight wheelstanding blue shortbox,with Matts old whippled 422 in it. When the engine was in Matts truck,it put down right around 1100 rwhp,they're pretty closed mouthed on whether it's still putting down those same numbers or if it's been leaned on even more ,now that it's in Ricks truck
Josh22855
Josh22855
Yeah I seen that blue truck run when it was N/A, now with that 422 Whipple combo it is going to be deep 9's/ high 8's quarter mile.
crazykid1994
Time to plate it. Or pull the motor mounts and fill them or weld them solid
Jim BB
Hamilton ,ON
2019 Ram 1500 classic Express
or make them your self if you are handy!
after mounts are fabed up chain and strap it up ! like the old days trans tailstock hoop and drive shaft hoops and trans scatter shield ! better safe than sorry !!!!!
Orca
