Won't Start
Tomslick
Truck was running fine pulled into work stalled out and won't start. Turns over. Full gas tank. Any suggestions 2007 5.7 Hemi
bhonshell42
Have you checked all fuses and relays?
Sent from my SM-T550 using Tapatalk
stimpy433
IOWA
Fuel pump??? That's what happen in my 2014..... drove around all morning running errands and at my last stop when I went to leave nothing. Truck tried to start but no go, and it was the fuel pump.
RonJon '06
Southern Minnesota
X2 on the fuel pump. There's a Schrader valve on the passenger' side fuel rail where you can check for fuel pressure.
djjab73
Did you figure this out? Just happened to me
Sent from my LG-D415 using Tapatalk
T
Tomslick
Yes sir
It was the fuel pump. Took it out caveman style in my yard. Replaced it with Chinese pump from EBay. About $100. Running fine since. Getting usual 11 mpg. Dealer can't even get one, because they were so problematic. Might as well go import since the oem parts suck anyway. Mopar baby!
djjab73
Well I got it home and was ready to replace it till my help came by. He went under truck with a piece of wood and beat on the charcoal canister then it started right. Put some seafoam in it and has been running good.
