Kap1
Ex Ram 1500 2013 owner
- Joined
- Nov 27, 2013
- Posts
- 680
- Reaction score
- 557
- Ram Year
- 2022 Tundra
- Engine
- 3.5 vvti
Hi All,
I've got a 2013 1500 QC Big Horn hemi 4x4 with almost 90k miles.
It's my daily driver and a work truck, has a camper shell and I estimate that my tools, supplies and the camper all together weigh approximately 1000-1200lb load total payload which I carry daily. Add to that myself 200 lb, and wife, and we're looking at a total load of the truck 1300lb minimum. I think I'm over the allowed payload ...
My truck has been a bit wobbly/jumpy on the freeway when I drive fast, around 75-85mph, especially if there are slight humps on the freeway. Back when truck was new, it was much more stable at high speeds than now.
I explained this situation to my mechanic, and he checked the front end and said that everything is fine, but one of the optional repairs is to replace front both lower ball joints with lower control arm as he noticed a little bit of play in these parts. He said not critical but normal wear and tear and that may contribute to some wobble.. And I can wait a year or two before doing it.
I don't know much about suspension .. What would you recommend to do in my situation. I want an increased stability while driving fast (as it was when truck was new) , try to increase payload and improve suspension so it doesn't sag or wear out fast since I do carry lots of weight with me at all times. I do not want a lift as I need to fit into garages in downtown. No lowering either.
Should I replace the parts as my mechanic suggests?
Upgrade springs? Shocks? Leafs? Anything else suspension related?
I think I need some components with higher payload rating?
I want to make sure it's the last suspension upgrade I'll do and it'll be good for another 100k+ miles. I don't get as much enjoyment cruising as before because truck is more wobbly and jumpy now. When it's not loaded it's still fun to drive, and no wobble. But I want to improve it so it handles better while loaded too
Thank you in advance!
