Thanks guys. Was a lot of hard work so means a lot. And what I did to ge the paint to stick to the grill is scuffed it up real good with 80 grit sand paper then I used an adhesion promoter as a primer and did about 3 coats of it, then I painted it with about 5 coats, then clear coated it with 3 or so coats. Stuck really well. I just took a trip from flagstaff to Phoenix about 150 miles through the mountains with bugs and some small rocks hitting it and no chipping or anything at all. Then took it through a car wash when I arrived and it's still in great shape. Going to be taking it to Vegas over the weekend too.
Thanks. Its all still holding up great too. I always use Rustoleum on anything I can because in my opinion it holds up better than the Duplicolor and is much easier to use. Thinking about adding a racing strip with plasti dip either down the middle or have a side strip on my bed later on but not sure what to do yet
