Need options for speaker replacements
JinxCanada
Windsor, Ontario, Canada
2010 Ram Sport
I have a 2010 Ram Sport (4 full doors) I dunno if that's called crew or quad? I need a list of speakers that will fit directly into the front and rear doors if possible. I do not have the Alpine stereo...just basic stereo and my front speakers sound like they are blown now. Any help would be VERY appreciated.
TIA
Jinx
stimpy433
IOWA
Go to crutchfields website and enter your truck info... it will give you lots of option on what speakers will fit.
JinxCanada
JinxCanada
2010 Ram Sport
i did that but it said I needed 6.5" speakers, however looking at the doors the cut outs certainly look like 16x9 speakers front and back. This is why I asked.
Wahrsuul
Central S.C.
In a Quad Cab, the rear seat doesn't have as much leg room as a Crew Cab, and the bed is a lot shorter.
stimpy433
IOWA
It's common to use 6.5" speakers (with an adapter plate) in the place of 6" x 9" speakers. If you order them thru Crutchfield, they will send you the required adapters with the speakers.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Stimpy is correct and Crutchfield is a good site, if for no other reason, to see what fits. I have the 2010 Crew, and have 6.5's in the front and rear, and 3.5's in the dash, a different head unit and an amp. Lifetime tech support from Crutchfield, too. Good luck!
JinxCanada
JinxCanada
2010 Ram Sport
so I was thinking about getting these since they are a pretty good deal for the front and back of my 2010 Ram Sport. The question I have is will they fit and also what speaker should I get to replace the small 3" speakers on the dash in the corners or should I bother with those at all?
https://www.amazon.com/JBL-GX962-2-Way-Coaxial-Loudspeakers/dp/B074FHZD4R?th=1
Thanks so much for the help and advise. I really HATE the way the stock stereo sounds....basic stereo no Alpine or anything. I also really want to add a subwoofer. Could I just cut a hole and use the cover and storage area as the box rather than buying a box for that area?
adrianp89
Tampa Bay, FL
Should fit fine, and we install a ton of the GX speakers, pretty good for the money.
JinxCanada
JinxCanada
2010 Ram Sport
awesome. now what about that 3" speaker on the dash? Does it need to be replaced and if so what should I get?
JinxCanada
JinxCanada
2010 Ram Sport
what should I use then to go with those 6x9 JBL door speakers? These 3.5" are the matching speakers so that's why I thought I'd get them.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
a good 3.5 in either 4, or 8 ohm. 8 ohm preferably.
JinxCanada
JinxCanada
2010 Ram Sport
So I called a local shop and they said I couldn't just replace my speakers because I'd need more power to drive new ones. Is this true? I thought I could just swap out the 6x9 for new speakers and it should work just fine. Any thoughts?
Graygoose
Oklahoma
Convert, for now.
small
LOL, they are trying to up-sell you...yes, of course you can replace just the speakers without adding amplifiers.
Now would they sound better with an amp, yes...but you can just replace speakers with no amp.
JinxCanada
JinxCanada
2010 Ram Sport
oh great! Perfect! Ya they said I needed a "mid driver" for the door because the Ram only has mid drivers...and then a tweeter for the dash and a 3 channel amplifier for that and the sub at a cost of $1500.00???!?!?! I thought that sounded a bit nutz and when I questioned him he got all pissy with me.
JinxCanada
JinxCanada
2010 Ram Sport
oh...also he said if I put 2way or 3way 6x9 in the doors they wouldn't work because of this mid driver issue? sounded like BS to me...so I wanted to ask you guys.
adrianp89
Tampa Bay, FL
If you had the Alpine System - he would be right.
If it was high-end equipment, the price isn't outrageous.
$100 - Install Components
$120 - Amp Install
$50 - LOC install
$150 - FoxBox
$30 - SpeedWire
$100 - Amp Kit
$30 - Two sets of RCAs
$30 - Two LOCs
$15 - Speaker Harness
That is $625 just in parts/labor.
A solid amp will be at least $300, figure $200 for component set and $200 for subwoofer, so $700 in equipment brings you to 1325.
Add in tax and you are right under $1500.
Of course equipment could be cheaper and you could do it your self.
DITRIO
