Replacing OEM Alpine subwoofer
jsnprice42
Hey all,
I have a 2017 1500 Sport with the 9-Speaker Alpine system. I would like to replace the stock subwoofer with an aftermarket sub that has better sound, but wondering if it is a "straight swap", or if there's anything extra I need to do.
I'm looking at the following sub as a replacement:
Dual 12" 1,600W Max Power Loaded Subwoofer Enclosure Compatible with 2002-2018 Dodge Ram Crew & Quad Cab Trucks​
I do see that the new sub box just has 1 audio in connection, and by what I've read elsewhere, the wiring harness has 4 wires, so which would I bypass and which would I use to connect to the new sub?
Also, keep in mind, this is only temporary. I do plan to replace the stock sub amp with an aftermarket amp (probably this one: https://skaraudio.com/products/rp-1200-1d-car-amplifier), but I'm impatient and want at least some better bass coming from the back seat now.
Any help is GREATLY appreciated!
Jason P
G-Ride990
Administrator
Chandler, AZ
5.7 No E-torque
If you are asking if you can just hook up that dual 12" subwoofer setup and use the stock amp, absolutely not.
The stock sub is maybe a couple hundred watts. It will never power that setup. I also highly doubt the stock amp is 1ohm stable.
If you want to add those dual 12's, that amp will pair well. Then use something like an Audiocontrol LC2i or a PAC audio AmpPRO for a signal.
