yea, but my Rigid SRQ pods take up more room than your how hooks so I don't have but maybe 1/4" at the top.
I also like that feature with yours. I did switchback Halos in my fogs when I had retrofitted Matchbox projectors in my fogs and they did a similar thing. However had the same issue where the DRL gets washed out when the Fog/projectors are in use. No external switching... all happened in a small DRL box.
My afternarket AlfaRex fogs have a DRL function (single wire coming out) and they are wired into my running lights so I can turn them on with the running lights (stock projector headlight housings so I can have my running lights with DRLs on without the fogs on. However when the fogs are activated the DRL's don't turn off and since they are in the fog housing the LEDs are bright and wash out the DRLs. I don't think the DRLs make sense being in the fogs so thats why I'm going with the Morimoto HXB 4 bangers. If I do the DRL it will be up high like OEM which is why I was looking at the underhood light. But the rest of what your saying makes sense. I Don't love mixing colors with the lighting... I would prefer to have everything white or amber and not a Mix as far as accent/DRL lighting goes. I also make sure to match my HID and LED color temps lol.
OK so, I’m confused…lol. You have the single wire for each one of your DRL’s in your fog lights wired to your marker lights, correct?
If I understand the problem you’re having correctly- I don’t understand why you would want your white DRL’s in your fog lights to be on with your marker lights because when you turn your fog lights on, those are definitely going to wash out your white DRL’s in your fog lights so that’s why I was saying a post ago that being that you just said you have the factory premium projector headlights, you should have that one wire going to each one of your headlight’s wiring harnesses that is your true dedicated DRL wire.
If you snip that wire on the truck side of the harness, you can essentially take those wires from your fog lights that power your DRL‘s and splice those into those wires and as long as you have your DRL’s activated within your body control module and set to “dedicated”, those DRL’s in your fog light housings will now only turn on when your ignition is on and running, and when you take the transmission out of park. They will turn off automatically when you turn your headlights on and they won’t affect how your fog lights work or detract from the rest of the orange light on the front of your truck at night.
You could even enable the DRL drop out but being that your DRL’s are all the way down there on the bottom of the bumper where your fog lights are, there’s really no need to have the DRL dropout enabled for whichever side turn signal is activated. Pretty much the only time you want that enabled is if you have DRL’s either inside or near your headlights so they don’t interfere with the visibility of your turn signals.
But yeah, I think DRL’s in the same housing as fog lights are a great idea if they’re hooked up correctly. Matter of fact, if I could’ve found a set that I liked, I probably would’ve exactly went that route but then again, I like how those lights I do have, have the automated start up sequence and the directional turn signals inside of them.
As far as mixing light colors, I feel the same way. That’s why my OPT 7 tailgate LED light bar is all red and doesn’t have orange turn signals because both my tail lights are completely red. If I would’ve had one of the new trucks, or if I could figure out a way to put a set of tail lights in my truck that had separate orange turn signals from the red brake lights, I’d have to buy a new tailgate bar because then I would want to turn signals on that to be orange just like the tail lights.
When I upgraded my highbeams to LED, I tried to match the color temperature as close as I could to my halogen low beams but I was pretty unsuccessful for the most part. I don’t worry about it too much, though. I wanted bright high beams but didn’t really want to go to much brighter than the custom-made HR1/9011 halogens I got from Daniel Stern lighting.
