2019 3.6 etorque no start no crank problem
devliegjohn
Michigan usa
3.6 etorque
Hey guys has anyone figured out how to trick the e-torque 48v system into using stop start function to start engine in the case of a low 12v battery?
dsherman26
Ohio
Nope. The start/stop is only if the ignition is on and the engine has been running. The 12 volt conventional starter is used when starting cold.
