4x4 not working
  1. W
    Dash Lights #broken harness
    I have a 2020 Ram Rebel Sport with a 5.7 Hemi in it. I was driving home last week hit a pot hole and my ABS, Traction control, front rear parking sensors light came on. Also 4x4 temporary out of service came on. Continued driving home and got underneath to check connections and found that...
  2. E
    2013 ram 1500 44-44 problems
    Hey all, so i know this transfercase has been discussed lots over the years but I cant seem to get an answer to my question. MY 2013 1500 4X4 just cant seem to get working 4 wheel drive. The truck has a 6 inch lift and 35s. its a sport 6 speed with the bw 44-44 transfercase with auto 4x4. When...
  3. Emmanuel
    2003 Dodge Ram 2500 wont shift out of 4 wheel drive
    Hey all, I'm having problems with my truck not disengaging 4wd. It's a 2003 Dodge Ram 2500 laramie with the 5.7 hemi. I was backing up a trailer and put it in 4wd his with the wheels at full lock. I looked down and saw that 4wd wasn't engaged from the switch and the light isn't appearing on the...
  4. C
    2016 RAM Rebel 4x4 not engaging
    The truck thinks everything is okay, when I press the 4x4 lock, or 4x4 low(in neutral) it indicates that it is working, (flashes twice and then light stays on until I “disengage” it again)but the 4x4 is not engaged. Never had any trouble with the 4x4, have 180,000km (111,800 miles) and no issues...
  5. D
    ABS and 4X4 lights on, changed sensors and connectors
    Hi guys, I’m at my wits end. Abs and traction control is malfunctioning, can’t use cruise and 4x4 won’t work either. I changed abs sensors, connectors but still no luck. Here is something strange though... If I am towing a trailer; it all works fine. As soon as I unhook the trailer and drive...
  6. P
    4x4 Problems.
    2010 Ram 1500 4x4 5.7Hemi I am having a strange problem. I was driving the other day, and my 4x4 neutral light came on by itself, the next day I had no 2wd. After playing with the 4x4 which I didn't have working the light went out, and then I had 2wd and 4wd. I did some testing shifting in and...
  7. T
    4X4 issues on a 2011 Longhorn
    Hi guys, last month, I bought a beautiful Longhorn, which has been taken really good care of, but has a LOT of mile on it. 185,000 to be exact. But they were for sure all highway miles. I have put a lot of mile on it myself, and it hasn't even gone through a half a quart of oil yet. Anyhow...
  8. Luis dodge
    2013 1500 5.7 lara longhorn 4x4 problem
    First time posting. I got this 2013 ram 1500 Laramie longhorn 4x4 with the 5.7 with the 6spd auto and BW 44 44. The 4x4 is not working. i put the rear end up on stands and put the truck in 4auto, 4 lock and 4 low but the front wheels are not moving. I should mention that after pressing the...
Sunmerk
