2014 5.7 2WD 120k miles. So I've been having this soft brake pedal issue for a year or so that comes and goes. I believe it is somehow caused by the ABS\Traction control system introducing air into the system when activated. It happens almost every time I get into the throttle really hard...
I have a 2016 1500 and have codes C2200-49 (ABS Module) and C0020-01 (ABS pump motor control). I've been doing a ton of research on this and have found that the pump motor on the Heavy Duty Rams has a very common issue where one or both of the brushes get stuck and cannot make contact. I have...
Hey Guys, Got a '09 Ram 1500 that keeps throwing intermittent right front wheel speed sensor codes.
I replaced the sensor and am still getting the code. It will go away when I clear it and then our of no where come on and go off 4-5 time before the srv 4wd light comes on. I think it is probably...
hi guys
my truck is a 98 5.2 rwd truck
it has this lights on with service engine light , changed the sensors but still on
i bought a repair manual but it has no picture of the abs plug
i took these tonight
can any of you with more knowledge tell me if this is right
the plug on the abs box under...
