'09 Ram 1500 ABS
Hop
Hey Guys, Got a '09 Ram 1500 that keeps throwing intermittent right front wheel speed sensor codes.
I replaced the sensor and am still getting the code. It will go away when I clear it and then our of no where come on and go off 4-5 time before the srv 4wd light comes on. I think it is probably a bad wire in a loom some place. does anyone have a wiring diagram for the abs? And what voltages are supposed to be seen on the wheel speed circuit? I need to do some tracing. I'm assuming the loom plug is located behind the driver fender from what I've read. Anyone trouble shot this before? On my scanner I haven't been able to record the wheel sensor not working. Just get a fault code that blips and sets everything off. Would be easy to find if the damn thing would completely break.
Thanks,
Hop
'09 1500 4x4 Sport Crew Hemi
