2014 5.7 2WD 120k miles. So I've been having this soft brake pedal issue for a year or so that comes and goes. I believe it is somehow caused by the ABS\Traction control system introducing air into the system when activated. It happens almost every time I get into the throttle really hard...
I have ohm tested rear speed sensors, I have replaced the front sensors and I still can not get my traction control and ABS light to go off. I have ohm tested all sensors against the new ones and all are very close in resistance. What else could be causing my issues any help is appreciated
