2019 1500 Laramie.
Factory installed bed lights have stopped working.
What I have done
1) Checked ground. Still connected but I need to pull it and clean it just in case.
2) pulled the driver light and checked voltage up to the switch. It's 12 volts.
3) tried checking switch for complete...
The led strip light link:
https://www.yitamotor.com/products/2x-pure-white-truck-bed-led-strip-light-for-chevy-silverado
Led Strip Light for Dodge Ram
The slim design makes it possible to place it anywhere you need lighting for greater safety and visibility.
- Simple design exterior truck...
LED Truck Bed Strip Lights installation on Dodge Ram
Here is the link of the led strip light in the video:
60" 2-Row LED Strip Light & Brake Reverse Signal for GMC RAM
https://www.yitamotor.com/products/60-2-row-led-strip-light-brake-reverse-signal-for-gmc-ram
$17.99
If you have any...
Is there any way to program your own OEM LED bed lighting for 2016 Dodge ram Laramie? All of the installation information I can find says you have to take it to the dealer for them to program it and it costs over a $100. I believe that to be a bit excessive and was wondering if there's any way...
I've been looking for a while now for the oem bed lights and can only find them as a kit. I have the wiring under the bed already so I really only need the lights and pigtails. When I find part numbers some mopar sites say the are incompatible while another will say they'll work, it's...
In this video I review how to install LED bed lighting on your truck! This is a step by step do it yourself video for those that want to tackle it on their own and shows what is involved.
With some patience and some simple planning you can wire and rig up your truck to have led lights in the...
