My blend door(s) are broken. Have been for some time but my AC would still push enough air through the vents to be liveable until a few days ago. Now the idiot light comes on but the clutch does not engage. Static check of the system pressure shows good. Does anyone know if the Blend/Recirc...
My cab/outside air recirculation blend door actuator started sounding like a little machine gun going off every time It wants to move so I went on the mopar parts diagram and ordered a Oem mopar actuator by the part number it gives for that actuator on that door now when I received the actuator...
I have replaced the two actuators right behind the temperature control panel (OEM), one after market actuator right behind the glove box, I know there are two more behind the dash. one is right behind the firewall (you have to disconnect and depressurize your a/c) and one you can just access...
Hey guys I have a 2014 Bighorn and recently lost ac on my drivers side vents but have ac on my passenger side. There is no ticking/clicking noises. And ac only works on the head setting for ac for all settings. I do have heat for all settings and for both sides. I see there's posts for the...
