bolt stuck
  1. R
    Solution for seized lower strut bolts, no cutting!
    Hello fellow wrenchers, I found a solution that worked for me to get the lower strut bolt loose without cutting. I took my Makita multitool and bent one of my old blades in a 90 degree angle. Then i crushed the end and forced it into the 21mm socket. Put some WD40 on the bolt and GENTLY apply a...
